frequency separation - add?
Doug.S
Postby Doug.S » Tue Jan 13, 2015 4:52 pm
Suggestion: since frequency separation (FS) is a valuable tool in the arsenal, Can you add some or all of the capabilities to generate the masks in CM?
I realize actions can be done in Ps and FS requires layers and CM may not be able to handle a set of layers....
but mask creation and export for use in Ps might add a new feature in CM to gain more users since FS seems hard to use by many people and an "easy" tool/masks might be valuable.  And some means on non-destructible adjustments may be needed to maximize use; even if it perhaps used smart layers in Ps.
Doug.S
Postby ggroess » Tue Jan 13, 2015 10:26 pm
CM does respect the layers in PS and can be used as a smart filter on a layer.
I'll nudge Mike to look at this but, CM does export a channel as a mask as a flat image copy to the clip board to be pasted to layer masks.
CM can handle a set of layers from outside as a stack from PS but not from within CM as separate layers in the module.  Some things are best left to PS.
Postby -default » Wed Jan 14, 2015 2:36 pm
The examples of Frequency separation that I'm familiar uses two or more layers, with differing levels of detail in the various layers.  There are no masks involved.  So I guess I'm not sure exactly what you would want CM to accomplish.
I've often thought of a mask exporter plugin, but it would be separate from CM, and not built-in.
Doug.S
Postby Doug.S » Thu Jan 15, 2015 10:08 pm
Thanks,
I did not know about how much CM could do with layers and smart objects etc.....will look deeper.
Somehow I was thinking the image detail layers in Ps for hi and lo freq. could be either created with or adjusted with a mask....but now that you mention that Ps uses filters on gray filled layers, I may be wrong about a CM feature to help with FS work.
Thanks for replying.
Doug
