I need a reminder on how to save a mask to paint in the black in photoshop and then return that mask to CM to finish it.
Thanks,
Tina
Masking
Go to CM.
Do mask, curve mask to taste.
Click on save button (It looks like file folders)
Cancel.
Add mask to layer.
Highlight mask and alt-click to make the screen white.
Paste CM mask. Control - V works (sometimes) or is it file or edit then paste.
the key point is to save the mask in CM. And alt clicking the photoshop layer mask and pasting.
Cancel.
Add mask to layer.
I have just learnt how to do this and I'm having problems
If I do this process but invert the mask using the 'invert' command in the mask menu things don't work properly
It looks like it might be pasting the un-inverted mask
Its certainly not pasting the mask I made
Is anyone else coming across this problem?
Any suggestions?
Any suggestions?
Users browsing this forum: Bing [Bot] and 7 guests
