Jacob Rus just posted (to the ACT list) about an L* ICC profile that somebody had recommended to him; information about using it (and the file itself) is available from here: http://www.libraw.org/articles/displaying_L_channel_in_Photoshop.html.
I've just installed it, and it's great!
I'm thinking that for the standalone app, LittleCMS would make adding this to CM4 fairly straightforward - no?
I am thinking that using this L* profile (or something similar) to preview the image in B/W would be very useful in CM4 - both for B/W conversion workflows, and when working in the 'Tone' tab.
Download the ICC profile and let me know what you think of it ;)
Previewing the image in Black & White...
But...Is this just not converting the L channel to match a RGB composite? The difference is when you switch on the "Show Colors"
Since Lab calculates the L channel differently than the RGB composite I would expect differences. If I use channels and show the data in the channels as is; when I copy channels and apply, then set the resulting layer to a luminosity layer am I not just fooling myself ahead of time so to speak...
I would say to stay true to the discussion we have had so far on this; you should be able to assign the profile in CM4 but making it the default display might be a bit arbitrary.
I'm not sure I see the value if we tackle each channel as a separate problem using the Zone system pins.
I must be missing something...
Good call about the channel blending :) Things start to get interesting though when we start working with the zone system and L* gamma: http://stonerosephotos.com/blog/?p=675
I just found this article, so I've only scanned through it quickly, but it seems really interesting and might have a bearing on the zone system aspect of the workflow/app.
Return to “Curvemeister 4 Beta”
