Pinning Skin Tones - Advanced workflow.
Postby ggroess » Thu Dec 31, 2009 2:11 am
As I work on skin tones in CM one of the biggest hurdles is knowing what "Skin Pin" to set.  I have created a few resources for you to use and build upon.
Lastly is the work flow...
