Copy a Mask to clipboard
I have had this issue with the image just as you have...
My shot 1 is the K mask I created.
Shot2 is the mask as pasted to the layer in PS.
It only seems to be this image..I'll have Mike look at the source file maybe it's messed up.
Try copying something else to the clip board and then opening PS and try it again.
It seems like sometimes with this image the mask copy is inverted and it gets stuck on the clipboard.
You can also try another channel like L the results will not be as good but it should be do-able.
I always thought it was just me being Lazy...or forgetful...
Looks like a slight bug for Mike...
Users browsing this forum: Google Adsense [Bot] and 36 guests
