Need help on a tool
kessi
Postby kessi » Thu Jan 29, 2009 10:01 am
There is a  little scroll next to the hue clock. See screenshot. When I click on it it gets a little red tick. What does it do? I couldn't find an answer in the Help manual.
kessi
Postby ggroess » Thu Jan 29, 2009 4:20 pm
The Yellow Scroll Icon is used by CM when you are using it as a smart filter in PS.  CM does not know if it was called into action by you or by the opening of the smart filter layer in PS.
So...
You have to check the scroll when you use CM as a smart filter so that it remembers the curves you applied when you come back from PS.
kessi
Postby kessi » Thu Jan 29, 2009 6:39 pm
So in other words it only works for PS and not PSE. I can therefore ignore it.
Thanks for the info Greg.
kessi
Postby ggroess » Thu Jan 29, 2009 8:38 pm
You can ignore it until you make the leap to PS....
I always said "why would I ever use the full install of PS?"...then...a funny thing happened...
I found myself wanting to go just a bit further....and while PSE does most of the work in my setting....I have PS for the really challenging images.
Postby mikemeister_admin » Thu Jan 29, 2009 9:47 pm
But expensive:(
Thomas
Postby ggroess » Thu Jan 29, 2009 10:01 pm
Oh I hear that....
too expensive if you ask most.....
Just my personal journey....I am a past PSE beta tester...I know what has been asked for in the past...
