Tough to get all the colors right!
Fruit Vendors Window
Good job...
Now for the challenge if you are up to it...Not required by any means.
Can you kill off some more of the green frame without messing up the rest of the image..
BTW it is ok to take multiple "passes" at an image in CM. Some images really demand it...you can solve part of the problem in RGB for instance and the rest you might have to re-open the image in CM and use LAB. Just something to think about.
In case you had not noticed...I tend to push things a bit...
