week3-exer 7
j2e4a8n
Postby j2e4a8n » Wed Oct 01, 2008 1:40 pm
Guessing by the numbers.  I fooled around until I got what was on the html file. . .
Postby ggroess » Thu Oct 02, 2008 4:04 pm
Jean can you post the entire image??
j2e4a8n
Postby j2e4a8n » Thu Oct 02, 2008 7:26 pm
After seeing  the  rgb_btn.swf  video.  I realised one has to, fool around a bit.
Here is the file>
Postby ggroess » Thu Oct 02, 2008 8:15 pm
Jean,
try pulling the shadow end of the composite curve in to the zone 1 mark or there abouts and see if the overall contrast is more pleasing...If you find it not to your liking you correction is pretty well done as well.
j2e4a8n
Postby j2e4a8n » Fri Oct 03, 2008 1:50 pm
yes it made the difference.
See a new one below with skin 1 pin applied to the women on top of the image.
Postby ggroess » Fri Oct 03, 2008 2:59 pm
Jean,
Try pinning the curve as shown with the red dots.
Then move the curve below the skin pin in the directions shown.  Let's see if you can have your cake and eat it too...
You should be able to hold the skin tones and keep the color cast from leaking into the image.
j2e4a8n
Postby j2e4a8n » Fri Oct 03, 2008 11:57 pm
Much nicer.
Your file looks has an image coming from an outer space alien on my monitor. (bought used Hitachi cm721f).
I putted a shadow and highlight point to it to appreciate.
Here is mine, which must look coming from deep space too.
Postby ggroess » Sat Oct 04, 2008 2:04 am
hmmm Jean, I fear that I am not getting the message through...that I may be confusing you more than helping.
The idea was to push the middle of the curve back to the center so that you remove the red cast that was introduced by the skin tone pin.
j2e4a8n
Postby j2e4a8n » Sat Oct 04, 2008 11:33 am
:o)
Maybe the blue arrows where not big enough.  Maybe I like an orangycathedral too much or women.  Women, could it be?
I get it.
Postby ggroess » Sat Oct 04, 2008 1:44 pm
Orangey women???  Jean I don't know what to say....
