week3-exer3 skin
j2e4a8n
Postby j2e4a8n » Mon Sep 29, 2008 7:37 pm
Hi,
I did them in Lab.
The laughing guy at the bottom left seems to work better in RGB.
Maybe the others would have too.  But it is the last one I did.
Postby ggroess » Mon Sep 29, 2008 7:44 pm
Jean,
When you did this did you use the selection tool so that the images created layers in PS?  you should end up with all of the skin tones corrected on one image....
j2e4a8n
Postby j2e4a8n » Tue Sep 30, 2008 11:32 am
I used the selection tool on one image (no layers) opened CM, the rest of the images remained masked.
By the way I like your skin pins ;-)
j2e4a8n
Postby j2e4a8n » Tue Sep 30, 2008 5:09 pm
Another trial.
I did the 3 linked by a red line after finding the same lab number somewhere in there respective picture.
Postby ggroess » Wed Oct 01, 2008 3:07 pm
Thanks for the note on the pins...
Does the process make sense??  I am still collecting feedback on that one.
