Week 1 Challange
Now...Brighten up the mid tones and see if you can add contrast to the scene. (Hint: Switch to LAB, in the L channel find a spot on the image with a long worm segment say 1/3 of the length of the grid and right click.)
Select "Contrast Pin". Place the cursor on the edge of the L channel frame so it shows you a bent double headed arrow, click and slowly drag that mouse across the grid frame. The contrast pin will separate the ends of the worm you located and increase the contrast of the image... It can decrease it if you go the wrong way.
Play around and see what happens....
