Quick Curves 2: Desert Trouble
Postby ggroess » Mon Sep 08, 2008 10:53 pm
Here is another troubled image.
Postby mikemeister_admin » Tue Sep 09, 2008 1:39 am
Going for the striations in the rock.A pass in Lab to lighten the foreground then passes in RGB for the sky and overall color.
Postby mikemeister_admin » Tue Sep 09, 2008 1:57 am
Levels adjustment in PS, then LAB mode curve and color adjustment in CM.
Postby mikemeister_admin » Tue Sep 09, 2008 10:11 am
Yes - a difficult decision, how much to lighten the rocks.
I've probably over done it, as it looks a bit surreal - but then it is the message I am trying to convey to the viewer, rather than a truthful reproduction.
All done in CM
pass 1 in rgb with L channel as inverted mask to lighten the rocks
pass 2 a little (?) lab saturation
pass 3 - blow in some more sky in Lab with inverted b channel mask
I really need to improve my masking as it looks very jagged at 200% - mind you the noise in the image is enormous.
I'd normally add some Mid tone contrast, but not with all this noise around
j2e4a8n
Postby j2e4a8n » Tue Sep 09, 2008 1:24 pm
I like it it is a kind of dantesque [Dante in the purgatory]
Postby ggroess » Tue Sep 09, 2008 1:33 pm
We will be showing you in class how to fix this without using levels... ;)
Postby mikemeister_admin » Tue Sep 09, 2008 8:55 pm
Concentrated on brightening the foreground, probably at the expense of the sky and background hills
Postby ggroess » Tue Sep 09, 2008 9:33 pm
Here is a hint...
http://www.curvemeister.com/wiki/index.php?title=Special_Curves:_Lizard_Tail
Again remember this is the week where we get to try things out and get used to some of the things curves can do.  For the new people, we would never expect you to get this technique without having seen it...
Postby mikemeister_admin » Tue Sep 09, 2008 9:50 pm
Not sure if I followed - but here's an attempt
Postby mikemeister_admin » Tue Sep 09, 2008 11:13 pm
English Paul,try the bottom lightness curve.Right Click in the lightness box and select pin grid>lower left,then the left side wont be affected.Those points you have at 50 and 75 can be moved back to the diagonal.What you want is a small dip at the spike in the histogram.I used quick selection tool in PSE6 so the action applied only to the rocks.GregM not Greg Groess.
