Street Vendor
Russ,
Thanks for posting the ACV file it helped a ton.
OK...The first shot is your curve showing the flat spot that is causing the weird colors. It is between the second and third lines fromt he left. it is hard to see because the tone of the worm is very close to the tone of the window. but if you place your mouse on the odly colored flat parts of the paper you will see the worm in the area I am trying to show...
Shot 2 is a possible solution to the image not necessarily the only one but a possible one for certain.
