The 3.0.8 version has several bugs fixed involving masking - for example the K channel is inverted in older versions of Curvemeister.
Here's the link:
OBTW - use the 3.0.8 beta version
Bill,
The most common reason for this is downloading the Photoshop and Elements version of the beta. The second link on the beta page is for the Elements Only version.
It could be a different problem. Let me know if this works.
I'm using the Elements only version. When I install the beta version it installs fine with the serial number appearing in the install window. However, after installation of the beta version I get a message that I have the demo version of the software and have been unable to get past that. So I uninstalled the beta and re-installed 3.01. What am I doing wrong?
