Threshold or Shadow/Highlight
Postby mikemeister_admin » Sun Aug 03, 2008 8:19 am
I might be missing something Greg,
I nearly always use the Shadow/Highlight setting as a way of correcting the image.
I realise that this also sets colour in rgb, but not in lab.
Looking at the Gorge solution - lab solution - it is recommended to use the Threshold method because there is no neutral balck/white points.  Why?
Postby ggroess » Mon Aug 04, 2008 7:01 pm
hmmm not the way I saw it..from the video Mike starts with the neutral and then thresholds...
You may have missed it...
Postby mikemeister_admin » Tue Aug 05, 2008 7:32 am
Ah, I havent made myself clear (as usual).
I was interested in the difference between setting a shadow/highlight via pins or doing it by moving the side of the curve dialog.
Why use the latter in preference to the former in LAB?
Postby derekfountain » Tue Aug 05, 2008 7:54 am
You mean using the curve thresholding for shadow/highlight, as opposed to setting pins? Thresholding is easier - no need to seek out the lightest and darkest areas, just move the threshold until you see the pattern in the image. Quick and simple, I use it all the time.
The downside is that when you change colourspace, you lose this adjustment. Pins stay put and are automatically applied to all colourspaces.
Postby ggroess » Tue Aug 05, 2008 1:17 pm
;D    ;D
Ahh.....
Thanks Derek...
It also helps to find the darkest areas when you are not sure..less hunting around...
I will frequently combine the two..I'll use the threshold to find where to put the pins...
