Sending in our work
Postby mikemeister_admin » Fri Aug 01, 2008 5:51 am
Hi,
I have finally finished week 1 and week2 today. Now I have a question.... might have saved them wrong.
Are we supposed to be saving the image with CM graphs showing?  If so, how?
The only way I know of getting the CM graphs with the pics is using a screen capture program...
What is the preferred format to save them in, and what format for uploading?
Thanks for all the help!
Tykee (aka Peggy)
Postby ggroess » Fri Aug 01, 2008 1:00 pm
Peggy,
You can do either one.  I need not have the graphs but they are handy to help me see what you are doing.
The use of a screen shot program is the fastest way..just make sure that you size the capture to fit the 200kb limit.
http://www.curvemeister.com/forum/index.php?topic=1879.0  This topic covers more on it.  it includes a link to a decent screenshot program that is free.
You can also save the curve as a file called an ACV file.  To save the curve as a file click the "save" button when you are done with your curves and before you click ok to finish with CM.  In the save as dialog you can save it to the desktop and attach it like any other file to a posting.
