Help problem
Postby imported_ganna » Fri Feb 22, 2008 6:37 pm
When I make a selection with Lasso tool and then try to open CM, CS3 acts like a mule.. put all fours in and won't move. See atached picture. Anybody else with this problem?
Postby mikemeister_admin » Fri Feb 22, 2008 6:40 pm
Ganna,
I have not CS3 but a better description of the error, you can find in the log-books.
frits
run: compmgmt.msc and you find the log-books
Postby ggroess » Fri Feb 22, 2008 6:41 pm
Cool..not so cool for you I'm sure...
Hard Crash....always interesting...
Mike will be very interested in this one...does the "more info" link list CM as the offending module??
If you have CM configured for error trapping from the Menu Bar you might have a log file Mike would like to see...
Postby -default » Fri Feb 22, 2008 6:42 pm
Yeow - this is a crash in Curvemeister. I would like to fix this if I can get it to happen.
Postby mikemeister_admin » Fri Feb 22, 2008 6:50 pm
Elements give no such a problem, i tried!
Postby imported_ganna » Fri Feb 22, 2008 6:51 pm
Mike, if this is of help, picture 2
Postby mikemeister_admin » Fri Feb 22, 2008 6:58 pm
Ganna,
i think it is of less help.
do run what i told you and you find the log-books and a lot more of information.
the errors are red. So you can find the most recent errors easily.
A copy of those are interesting for Mike,
Indeed also a CM log book.
p.s. click on the technical help from the popup!
Postby imported_ganna » Fri Feb 22, 2008 7:07 pm
Might have struck Gold! It only happens when CS3 is on 16 bits per channel. Works fine when I change to 8 bits per channel before opening CM.
Postby -default » Fri Feb 22, 2008 7:16 pm
Thanks!  I can get an error every time, though not quite the same error you got, I have a bug to chase.
