Ex 2
Postby mikemeister_admin » Thu Feb 14, 2008 11:10 am
This is my shot at nu 2.
I would normally mask out the boat, but as I'm forced to run CM from the background layer, I do not see a simple solution to this and I await the video to see what I should have done.
I'm not bothering to post the curves as they do not include the mask data!
Postby -default » Thu Feb 14, 2008 3:44 pm
Hi Zog,
The boat will be changed, since it it about as bright as the sky.  Using the b channel as a mask or H, might provide a solution, since that would darken the blue objects.
I thought the background layer issue affected wgCMYK hue clocks only.  Is the problem affecting Lab mode too?
I am able to re-create the hue clock problem, BTW.
Postby mikemeister_admin » Thu Feb 14, 2008 4:14 pm
You are half correct Mike, the clocks dont work, but neither does controlClick to get a point on a curve - I had assumed the mask wouldnt work, but it does.
Chris
Users browsing this forum: Bing [Bot] and 6 guests
