Banner
It was fun changing to all different colors
Week 2 Ex. 4
In CMYK the K channel is the "black" ink. Your image has too much black ink in it. The GCR setting helps describe the "ink" in my understanding...you set it to "light" so that it is not getting multiplied by CM to fit a specific printing setting.
The adjustment of the K channel is an interesting area to explore. It has some very dramatic effects on the shadow density of your images. Give it a test flight and see if you can open up the shadows and let some of the hidden detail shine through...not to much though...Remember you need blacks or the image will look flat.
