Here is my attempt at the Duck in both LAB and RGB. It has taken me longer that expected. I have been away from curvemeister too long and even downloading the files confused me. I tend to like the RGB example as I find the LAB too green.
Barry
Dark Day in Duck Land
Barry, The ducks look good if you are concerned about the green in lab try moving the neutral point around a bit and see if you can find a better place on the grey band. It might be a sample size issue or just a lot of off color pixels under your sample. Fritz had the same effect...
