I think Gloria might have mentioned this one, but in case I'm confusing her posts I'll report it:
I open an image and run CM3, which comes up in RGB mode. I use "Quick pin to original color" to set a point, then go to the blue curve (which now has just the one point on it) and click-drag on the blue curve's bottom margin. CM3 and PS disappear. No crash report, nothing.
Seems 100% reproducible for me.
Pin, rotate, gone
