hi everybody,
I discovered 2 little bugs in cm3:
1. when I open cm3 from PSE3 the preview screen stays empty so I have to zoom in or out to get the preview. If I hit the fit to screen button instead, cm3 closes instantly giving me an error message: DVPDoc::ReadChannel: readPixelsProc error:PARM ???
2. when I select the black(k) mask in masking mode and build a mask adjusing my curves etc everything is ok . But when I hit the apply button the mask behaves inverted so that I have to invert the mask. :-
2 little glitches in cm3
Very nice bugs, I must say. I'd like to chase these down for the next version and will try to re-create them myself.
Can you provide the zoom factor and image size? I've seen the PARM error in situations involving very small images that have been zoomed way out. It's also possible that there is an unusual channel structure.
