Bev Session 1 Examples 3 and 4
Postby mikemeister_admin » Mon Jun 04, 2007 10:50 pm
Hi again
Here are my No.3 and 4 examples. I used RGB for these too.  Cheers Bev
Postby -default » Tue Jun 05, 2007 9:30 am
These are much improved over the original images, but the brightest areas are still a little muted.  Try going into Lab mode, and dragging the right vertical edge of the Lightness graph toward the center, until you see parts of the image being brightly accented.  Then back off just a bit until there is just a salt-sprinkling of accented white pixels.  This is the point at which you have given the image a full range from black to white.
Postby ggroess » Tue Jun 05, 2007 11:23 pm
