Text Boxes block view of Histogram end points
Postby mikemeister_admin » Mon Jul 24, 2006 2:19 pm
Curvemeister is a great plugin, but one thing that frustrates me, is the 2 text boxes in the lower right of the curve screens, block your view when trying to adjust the end points to match the end point of the histogram.  These need to be placed somewhere where it is unlikely that there will be histogram data, such as the upper portion of the dialog.
RonBoyd
Postby RonBoyd » Mon Jul 24, 2006 3:44 pm
I, too, have the same complaint. (In fact, it is my only one.)
Ron
Postby -default » Fri Aug 04, 2006 9:23 am
Good point - Curvemeister tries to move the text boxes out of the way automatically.  There are situations where this automatic process does not work conveniently.
There are two manual controls for this.  You can click on the small arrow between the text boxes, which will move them to the next corner.  You may also specify in the options that you would like the boxes to appear in the top left (see attached image).
I hope this addresses the issue - if not, please let me know.
Postby mikemeister_admin » Wed Aug 09, 2006 1:24 pm
That is perfect. Upper left is where it should be. Thanks Curvemeister ;D
