I think that it would be nice if the histograms dynamically updated as you change the curves.
Dynamic Histogram change when curve changes
There is one case where this happens currently, and that is in the RGB and CMYK master curves - the histogram will slide around to reflect any adjustment you make to the other curves.
The problem with changing the histogram in, for example, the individual channels is that the histogram will no longer match up with the curve. One solution to this is to display both the original and modified histograms in the curve box, but that strikes me as too confusing. Another is to have the histogram appear independently of the curve, in its own window.
Both of these are just a bit too complicated, IMHO, and I'm concerned that they would cause more confusion.
