Andre's "Serious Mimi" image
Postby -default » Sat Jun 10, 2006 11:45 pm
Here's a version of Andre's Serious Mimi image.
The image does well in RGB with a shadow in the darker part of the hair, and a neutral placed in the lighter part of the hair.
After these changes, the hue clock showed a good "lunch hour" skin tone everywhere except the brightest part of the right cheek, which was still too yellow.  To fix this, I moved the bright end of the green channel vertically until the hue clock pointed a good skin tone.
Finally, I used the "floating neutral" feature to modify the overall brightness.
You may paste this text into Curvemeister to get the curve:
RGB 01-09-06_1349 copy 2:
;Red:  (39,0) (97,86) (255,255)
;Green:  (50,0) (138,86) (255,234)
;Blue:  (46,0) (145,86) (255,255)
Red: (0.153,0.000), (0.380,0.337), (1.000,1.000)
Green: (0.196,0.000), (0.541,0.337), (1.000,0.916)
Blue: (0.180,0.000), (0.569,0.337), (1.000,1.000)
Postby mikemeister_admin » Sun Jun 11, 2006 8:45 pm
Ì did it also but a simpler way.
I loaded the picture first in P.S.E. 4.0
then a shadow.highlight on 25 %.
then I did the usual way with blackpoint highlight in Curvemeister.
Then I placed a neutral on the eyeball and a pin 1 skin  on the skin.
After that a little bit bumping the colors.
frits
Postby -default » Sun Jun 11, 2006 10:33 pm
Nice one, Frits!
I think your hair color is more accurate, judging from the other photograph.
Postby mikemeister_admin » Sun Jun 11, 2006 10:39 pm
Nice one, Frits!
That is the reason why I did the picture again.
Postby -default » Tue Jun 13, 2006 7:08 am
Nice one, Frits!
Whatever your reason may be, this is an excellent result!
Postby mikemeister_admin » Thu Jun 22, 2006 11:53 pm
Frits, I like the way you did this image. What did you mean by " then a shadow.highlight on 25%".
Thanks Joe S
Postby mikemeister_admin » Fri Jun 23, 2006 2:34 am
How do you paste this info in Curvemeister to get the curves?
Postby mikemeister_admin » Fri Jun 23, 2006 6:11 am
Thanks Joe S
Joes,
In Photoshop Elements 4.0 there is a way to do that.
That is a sort of mask you can manipulate.
see the picture.
Postby -default » Mon Jun 26, 2006 8:08 pm
Hi Andre,
Copy the text to the clipboard, and then paste it into curvemeister.
If that does not work, you can manually enter the curve values.
