Jim,
Now if you drag the point around a bit you will see a thresholding effect.
http://www.curvemeister.com/wiki/index.php?title=Thresholding_Using_Highlight_and_Shadow_Points
This is how you can shop around for the darkest shadow detail.
Remember that you want to find the darkest significant shadow. It's about finding what makes the image look best not just the darkest shadow.
Quick Curves 2: Desert Trouble
