do I need both 32-bit and 64-bit CM when running CS5.1 under W7-64 bit?
DougJ
Postby DougJ » Wed May 02, 2012 8:14 am
My thanks to Mike and Greg for their recent posts.
My system is stable; I've images to post process;  and, I can get by with making a trip into 64-bit CM as needed.  So I'm just going to bide my time and we'll all see if anyone else reports loss of GL.
In due course I'll install again the 32-bit CM on my 64-bit W7 drive and will report back at that time on what I observe--problem, or no problem.
Ciao,
Doug
Postby -default » Wed May 02, 2012 10:08 am
Thanks, Doug.  Meantime I'm working on a new dialog that allows you to control the folder where pins are saved.
It's turning into more of a major feature than I planned - often the case.  You can browse for a new folder, and there is a "Fix" button that tries to open up write permission on all the files in the folder heirarchy.
If (big if) there are no interruptions, this should be available by the weekend.
Postby -default » Wed May 02, 2012 10:09 am
Doug, Most important, I am glad we have you set for the time being!
Postby ggroess » Wed May 02, 2012 7:01 pm
Ciao,
Doug
Doug,
There is a lot of Open GL forum posts on the NVIDIA site most go back into 2011 but the issues are there across the board for Open GL and NVIDIA cards...your card was mentioned a few times in the forum strings.
I would agree with Mike that you should get the Drivers from NVIDIA and see if the latest version still has Open GL issues.
DougJ
Postby DougJ » Thu May 03, 2012 5:54 am
As of a week ago, Greg, I've got the latest drivers for my video card installed.  I'll check back with NVDIA from time to time looking for a further update.
In the meantime, post processing proceeds. :)
Ciao,
Doug
