Author Topic: CM radio button missing  (Read 3041 times)
Offline Avastro
« on: June 19, 2006, 08:01:29 AM »
Hi,
I’m new to CM, using the demo version for now.
When CM curve window is maximized, working with CS2, to fine tune some points and back to the minimized window the RGB radio button, in the right side, is gone. HSB, LAB and wg-CMYK radio buttons are still there.
Is it something already identified or am I doing something wrong?
Cheers
Avastro
Offline Avastro
Re: CM radio button missing
« Reply #1 on: June 22, 2006, 07:38:52 AM »
Hi,
Sorry for the dumb question!  ???
Resizing the curve windows solved my problem, all the radio button are there.
Avastro
Offline curvemeister
« Reply #2 on: June 27, 2006, 01:41:52 AM »
Several people have pointed out this problem with the initial size of the window on some systems.  The main reason I haven't fixed it yet is that it is relatively difficult to recreate once you have resized the window.
