Author Topic: Sunset image  (Read 3819 times)
Offline derekfountain
Sunset image
« on: May 11, 2007, 09:47:49 AM »
See what you can do with this sunset image. The photo is washed out and somewhat over exposed. The original scene had much stronger colours and a rather threatening atmostphere.
Offline themightyzog
Re: Sunset image
« Reply #1 on: May 11, 2007, 11:46:44 AM »
Oh what fun Derek,
I tried the Man from Mars approach, having set the points in RGB, the rest was in Lab.
My wife says it is horrible, but I enjoyed over doing this one.
I look forward to seeing a 'proper' take on it.
Offline Greg Groess
Re: Sunset image
« Reply #2 on: May 11, 2007, 01:08:34 PM »
So very subjective.....
Nice image....
Offline Frits
Re: Sunset image
« Reply #3 on: May 12, 2007, 01:19:56 AM »
one, like greg!
and one sharpenend!
Re: Sunset image
« Reply #4 on: May 12, 2007, 04:47:57 AM »
Oh what fun Derek,
Wow, you don't do things by halves, do you? :) You've made it look more like a painting.
Here's by best effort. It's probably closer to the original scene than most others - it was nearly dark and the clouds were heavy. I've over done the orange, since it didn't really look quite like that. Greg was right, it's highly subjective, which is interesting in that you can do all sorts of things with the image and it still looks 'right'.
I took several goes at this and came up with a strange solution. I tried first in Lab mode, as is my habit, but I didn't quite get the pop I was after. So I saved that on a new layer for reference and went back to the original, having another go this time in HSB mode. Making the HSB saturation curve very steep gave me the pop I was after but it somehow didn't look quite right, especially compared to the Lab version. So I put the HSB version at the bottom of the layer stack and the Lab version on top, then set the Lab layer's opacity to 50%. This seemed to give the best of both worlds.
Re: Sunset image
« Reply #5 on: May 12, 2007, 04:52:32 AM »
one, like greg!
and one sharpenend!
I'm not sure I like the sharpening. It looks like a posterisation effect has been applied! Where you viewing the image at full size when you ran the sharpening filter?
Offline Frits
Re: Sunset image
« Reply #6 on: May 12, 2007, 06:51:03 AM »
In full size you are right.
The only thing I did, was more saturation.
After that sharpening with Crispimage pro!
