The biggest reasons to go to PSE 5.0 from my standpoint are...Better DB support for the Organizer in the background.For PRE 3. They fixed some vexing issues with large file support for JPEG imports. The 2.0 version slowed way down on conversion and render of slide shows if the image is bigger than 800X640. They also added support for smaller file exports <cell phones and web devices> . Better playback and editing tools. They handle the audio editing better. Effects and transitions are also a bit easier to use. Just my impressions...Greg
In the footage from Adobe...Yes, they were a forced Tulip bowl from Holland. They came in a clear vase and were just bulbs in water...They lasted for a solid 2 weeks...Very lovely.
It was odd to have to say the same thing about 10 times because they wanted the dialog to be just so...
oh, I have no pity for them either...Don't even get me started on Microsoft....I guess I just wanted you to know that the process is open to you if you want to be included. Most of the time you need to ask, be willing to be interviewed, and put forth the time to try to make a difference...Greg
