Author Topic: Canyon Conumdrum  (Read 20401 times)
Online Greg Groess
Re: Canyon Conumdrum
« Reply #45 on: September 05, 2008, 06:48:45 AM »
Latte' at the corner espresso bar...
day dreaming....
admin stuff I understand....lol Kidding...
BTW I want to learn more about this LAB L channel copy process. I tried it last night and I think I only have about half the story. I seem to be missing the point...
Sigh...
Offline themightyzog
« Reply #46 on: September 05, 2008, 09:51:17 AM »
Here is an action which you start from an rgb image.  It create a duplicate image and set up the layers for you in Lab mode.
The action is called ColourByTones and uses FlatCurve - ignore the rest of the stuff
The action only does the L channel duplicate at the moment, but remember you can use any channel as the seed, and to blow your mind you can select different 'masks' to seed each of the 3 lab channels - that's why I've split up the action, to experiment.
Have fun and tell us what you think
Chris
Online Greg Groess
« Reply #47 on: September 05, 2008, 01:10:56 PM »
I shall give this a test fly...
I knew you'd distill this down to an action....I kind of thought it was a lot of steps for anyone to try to remember it all.
« Reply #48 on: September 05, 2008, 03:31:58 PM »
If you could then tell me how to use CM instead of PS's curves - that would be great, but I can not work out how it could be done.
Online Greg Groess
« Reply #49 on: September 05, 2008, 09:04:11 PM »
could you eliminate the curves layer since you are going to do curves on the layer below it??
Seems to me the need for the curve layer is a PS problem....
take a run at it..I'm going to as well
Offline gremurphoto
« Reply #50 on: November 14, 2008, 03:36:44 PM »
In Lab
Offline jacobolus
« Reply #51 on: November 19, 2008, 03:20:18 PM »
Greg, did you ever try the action I put up here: http://www.hcs.harvard.edu/~jrus/colortheory/Jacob's-Ladder.atn
Online Greg Groess
« Reply #52 on: November 19, 2008, 07:08:20 PM »
I am still struggling with this.  I have to go back and re-read the original posting...I just seem to be messing the image up worse that it was...
I can see the subtle adjust ability here and I want to understand more about this.  I'm going to read up again....
Thanks for the nudge...
Time to go to school
Offline brookrouge
« Reply #53 on: March 12, 2009, 01:13:04 PM »
Here is my stab at it, the first one I adjusted in RGB and the second in LAB. If anyone is still checking this thread, let me know what you think.
Offline brookrouge
« Reply #54 on: March 12, 2009, 01:15:10 PM »
OOPS, I didn't add the images...
Online Greg Groess
« Reply #55 on: March 12, 2009, 03:17:46 PM »
Oh I'm checking...
I'll have more to say later on...
Online Greg Groess
« Reply #56 on: March 13, 2009, 07:40:57 AM »
Brookrouge,
Take your first image back into CM in Lab and try to boost the color a bit...
See what happens to it...It looks pretty good so far..there is more in there as you have seen.
Offline ThomasD
« Reply #57 on: March 21, 2009, 08:13:07 AM »
Just found this nice picture. Tried to apply my standard workflow. First corrections in Lightroom, setting neutral, inceasing exposure, contrast, saturation, clarity and some sharpen. Exported to PSE and made some final adjustments in PSE/CM first adjusting colours and neutral in RGB. Then to Lab mode and  fine adjusted BW and increased saturation. Very fast worflow but do not like that I sharpen before going to PSE/CM.
Thomas
PS There is a blue haze in the background which I tried to limit with a mask and decease blue. DS
Offline brookrouge
« Reply #58 on: March 23, 2009, 10:41:25 AM »
I was able to remove the blue hue without using a mask, I'll keep working on it when I have time. Thanks for the feedback.
