Author Topic: No pin palette  (Read 4186 times)
Offline ianbowie
No pin palette
« on: April 08, 2007, 05:55:31 AM »
Hi,
I used to have it - but now it is gone.
I open up CM but when I click on pin - I do not get the pin palette displayed.
I know it worked before - may be only in the beta?
Any troubleshooting?
Offline ianbowie
Re: No pin palette
« Reply #1 on: April 08, 2007, 06:03:22 AM »
I closed down PS and re-opened it - the PIN palette appeared docked to the side of the image and I was able to undock it.
Will try and re-create the problem (I guess it was hidden behind the image?)
Offline curvemeister
Re: No pin palette
« Reply #2 on: April 10, 2007, 02:04:48 AM »
I'd be interested in tracking this problem down.  This behavior has come up before, and gone away I believe after removing and re-installing Curvemeister.
Offline ianbowie
Re: No pin palette
« Reply #3 on: April 11, 2007, 02:25:42 PM »
I will attempt to recreate it -seems "fixed" when I restarted PS. (Pins docked with CM screen).
Regards
Ian
Offline Jean Pierre
Re: No pin palette
« Reply #4 on: August 25, 2009, 09:27:44 AM »
Am I in the right thread?
I just installed CM_64_3.0.13b on Vista 64.
When I clicked on the pin icon to open the pin tab Photoshop crashes.
Re: No pin palette
« Reply #5 on: August 31, 2009, 11:50:04 AM »
Hi Jean,
This thread is fine - sometimes it takes me longer to find a problem if it is added to an old thread, so when in doubt, create a new thread.
Pin Palette crashes are usually caused by problems with the .txt file defining the pins.  If you know which pin file you had active - probably your paint samples, perhaps you could email it to me and I'll try to recreate the problem.  This could also be a new problem with 64 bits only.
In the meantime you are OK with using the 32 bit version?
Offline Jean Pierre
Re: No pin palette
« Reply #6 on: September 12, 2009, 11:32:43 AM »
Ho yes, the 32 bits works fine.
The pins files where in the swatches folder witch is in the 64bits Program Data folder.
Some of them has the same name has the one in the goodies folder.
Jean
