Well, the darndest thing happened. I loaded your image, Derek, and as is often the case, the image came up perfectly. No white areas. Then when I clicked OK, another bug I've been chasing occurred: the Photoshop window refused to come to the front.So - this is an important clue to a new bug. I will take a crack at improving the handling of layers that overlap the curvemeister window. There are no guarantees that I will be able to fix this problem before it is time for me to move on to Curvemeister 3.OTOH several other bugs that you found are addressed in the 2.3 release.
I tested on XP, using Photoshop CS2 - perhaps you are using a different combination of OS and Photoshop version?
Now - all I have to do is fix the problem!
It is for me years ago, say 1979 1980-81 that I have done something in a prgr-language.never C++. I did somewhat in BASIC assembler and forth. ( not forthran).I have tried a little in Pascal.So, nowadays I think I could n't.These days assembler was relativ easy. I programmed the 6502 with 50 opcodes.frits
