Author Topic: Downsampling with ImageMagick  (Read 342 times)
Offline pictus
« on: January 10, 2012, 12:23:11 AM »
Download and install ImageMagick:
http://www.imagemagick.org/script/binary-releases.php#windows
http://www.imagemagick.org/script/binary-releases.php#macosx
http://www.imagemagick.org/script/binary-releases.php#unix
Download and unpack into your DeskTop
http://dl.dropbox.com/u/4686872/Pictus-resize2.zip
or http://www.mediafire.com/file/w47dqrjrzds3ffy/Pictus-resize2.zip
It contains some BAT files
To resize, just drag and drop any image over one of the icons in the DeskTop
The result is better than the other programs as it is free from moiré and gamma corrected during resize.
The original image http://www.mediafire.com/?49ahiwm5ukfu6c9
More details:
ImageMagick resize http://www.imagemagick.org/Usage/resize/
ImageMagick and USM http://redskiesatnight.com/2005/04/06/sharpening-using-image-magick/
Resize and gamma http://www.4p8.com/eric.brasseur/gamma.html
The BAT files are versions from http://www.openphotographyforums.com/forums/showthread.php?t=14947
« Last Edit: January 11, 2012, 03:04:35 PM by pictus »
Offline Greg Groess
Re: Downsampling with ImageMagick
« Reply #1 on: January 10, 2012, 03:54:01 PM »
Um...wow that is a lot of stuff to absorb....
Do you have any further examples?  I'd like to see the sharpening side as well as the downsize....
Offline pictus
« Reply #2 on: January 11, 2012, 03:06:47 PM »
Only the stuff about gamma and resize http://www.4p8.com/eric.brasseur/gamma.html
I did the final update, I guess now looks OK :)
