Author Topic: a bad orginal, though talking image  (Read 254 times)
Offline headlights
« on: November 17, 2011, 02:20:12 PM »
His gf is very talented designer and did take this shot with a point and shoot.
Photography is not here thing. But still she loves him and she has eyes.
I do not even think of posting my first tries on this image.
Perhaps you have idea's on this one.
« Last Edit: November 17, 2011, 02:28:11 PM by headlights »
Offline Greg Groess
Re: a bad orginal, though talking image
« Reply #1 on: November 17, 2011, 02:51:20 PM »
Highlights,
Please give us some goals you would like to have for the image.
Personally I can see that it needs a pass with smart sharpen, it needs a skin correction which could be done in Curvemeister with a Skin Mask and a mid-tone skin pin, The foreground road is completely blown out with no details; it will need to be cloned back into the image.  the overall color balance needs a bit of a tweak...
What things are you looking to improve and then we'll have a bash at it...
Offline headlights
« Reply #2 on: November 17, 2011, 03:33:29 PM »
thnx ,  i ll work with your tips. ok?
Regards,
Martijn
Offline Greg Groess
« Reply #3 on: November 18, 2011, 09:50:27 PM »
Headlights,
Here is my version of the image...
In shot 1: I show the image with the road cloned into a separate layer.  I copied a section of the road and pasted it into a new layer.  I used the "Skew" command to stretch the copied area out over the blown area and then set the layer opacity to 65%.  I then used a eraser tool with a soft brush to erase out the areas of the copied layer that covered the green spots near the middle.
In Shot 2: I flattened the layers and opened the image in Curvemeister to do a RGB correction using the highlights in the trees I found a spot that I thought should be white and corrected the highlights to that spot.  I picked a mid-tone spot and corrected in RGB to make that neutral.  I picked a spot in the hairline to check the shadows and found the hair to be blue.  I corrected the hairline spot to be in the skin tone range but very dark so that the man does not have blue hair.
In Shot 3: I applied smart sharpen as shown with the settings you see in the screen shot.
Shot 4 is where I left the image for now.
