Author Topic: Window Light?  (Read 443 times)
Offline Greg Groess
Window Light?
« on: September 18, 2011, 10:10:55 AM »
Ok a play on words....
Help this image along with some better balance, drama and color.  No specific goals here just make it look as good as possible.
Offline themightyzog
Re: Window Light?
« Reply #1 on: September 18, 2011, 10:26:54 AM »
Just to show how out of touch I am - this is my quick correction
I await to see how bad it is compare to a 'proper' workflow
Offline ganna
Re: Window Light?
« Reply #2 on: September 18, 2011, 11:27:14 AM »
Why not overdo it ;D  I threw it into Photomatix for a HDR feeling and then curved it and sharpened it
Offline Greg Groess
Re: Window Light?
« Reply #3 on: September 18, 2011, 03:46:44 PM »
Wow Ganna..The wall positively bleeds on my monitor...I like the effect...But....
I took this a different direction from where you have it...
For me, I wanted the window frame to be neutral and the rust colored areas to have as much color differentiation as possible.  I wanted the area under the frame to be "bluer" in appearance since it seemed like there was little or no Blue or Green in the image.  This makes a fine Black and White by the way; because it so monotone...
1) I opened with a contrast and tonal modification using CM on the Red and Green channels individually.  I set the Shadow and Highlight points on both Red and Green and adjusted the mid-tone contrast a bit to make the image overall "snappier".  I then copied the finished Red channel into the Blue channel.  I applied this as a Luminosity Layer and flattened the image.  I could have used the Zone system pins in CM but I found the contrast in the mid-tones  fairly easily.
2) Next step was a By the Numbers correction <See Screen Shot> I copied the image onto a layer and applied the BTN result in Color Mode.  I flattened the image again.
3) In CM I switched to LAB for a color expansion.  I set a hue clock on the edge of the window frame to act as my color anchor and then using contrast pins I expanded the A channel by selecting two points on the red side of the channel and increasing the contrast between them.  I then moved the two points downward in this case until the hue clock A channel value matched up to the original one.   I moved onto the B channel and selected two points for the B channel expansion.  Keeping my goals in mind I placed on pin under the window and one pin in the "yellow" area near some rust.  I again applied a contrast pin move to the selected points and returned the B channel value at the hue clock back to where it started.   I applied this layer in normal mode. <See butterfly image...>
4) Sharpened using a Highpass filter set to 1.7 pixels and reduced the opacity of the sharpen layer to 75%.  <Final Image>
That's about it...
« Last Edit: September 18, 2011, 04:29:41 PM by Greg Groess »
Offline gremurphoto
Re: Window Light?
« Reply #4 on: September 22, 2011, 10:53:58 AM »
Nice,Greg.I like how you got slightly different overal colors for the upper and lower sections of the window.GregM
Also you and Zog kept the checkering to the bottom wood frame.
« Last Edit: September 22, 2011, 11:01:41 AM by gremurphoto »
Offline Greg Groess
Re: Window Light?
« Reply #5 on: September 23, 2011, 10:45:14 AM »
The variation is due to expanding the colors in the B channel in LAB.  It's a great technique that give you lots of control.
