Author Topic: Delete option greyed out in context menu  (Read 1009 times)
Offline henri
« on: June 22, 2011, 04:37:15 AM »
Hi,
I have just upgraded to v 3.3.3 from V 3.3.0 and I have noticed that the delete option on the context menu for colour samples (ie highlight and shadow sampling for example) is permanently greyed out.I can work around this by opening the "show info" for the sample and then closing it; this then deletes the sample point.
I am running photoshop CS2, Win xp with SP3. This is when I am working in LAB mode; in RGB mode the delete option does not show up at all in the context menu.
I am wondering if there is an option that I have have unchecked by accident or whether this is inherent to V3.3.3.
As I said it can be worked around but it adds a keystroke or two...not much in terms of life, I agree, but very slightly annoying at best.
Henri
Offline Greg Groess
Re: Delete option greyed out in context menu
« Reply #1 on: June 22, 2011, 08:22:20 AM »
I'll try to re-create this in 3.3.5 I have not tried this one....
Hang in there...
Offline henri
« Reply #2 on: June 22, 2011, 02:23:05 PM »
Thanks for the swift response.
I have found that just hitting the "delete" key will delete the selected sample.
Should I try V3.3.5?
Cheers
Henri
Offline Greg Groess
« Reply #3 on: June 22, 2011, 08:35:20 PM »
I would...It is not a beta...
Offline henri
« Reply #4 on: June 23, 2011, 02:46:56 AM »
Thanks, Greg,
I'll download it and let you know.
Henri
Offline Greg Groess
« Reply #5 on: June 23, 2011, 07:42:33 PM »
Well I'll be...V3.3.5
Mike... you need to fix that one...
The delete is indeed greyed out on the right click menu...
The delete key does in fact work on the selected point...
Offline henri
« Reply #6 on: June 25, 2011, 02:27:00 AM »
Hi, Greg,
I am glad it was not only me!
I have installed V 3.3.5 and now... the "delete" option has totally vanished from the context menu???!!!
Could it have to do with the fact that I am running CS2 or with the soon to be lamented XP?
In any case thanks for having kept at it. I'll be watching for developments although ,as the delete key works, it is more a minor nuisance than anything else.
I am incredibly grateful and amazed  at your fast and helpful level of response!
Thank you!
Henri
PS do you guys ever sleep?
Offline Greg Groess
« Reply #7 on: June 25, 2011, 07:05:51 AM »
Thankfully yes we sleep...
The forum and site are a passion for us and we do work hard to make sure you are satisfied with the product you have purchased.  We want CM to be the best and we want you to have full use of it...
The XP and CS2 issues are not a part of this as far as I know.  I'll defer to Mike on this.
Offline henri
« Reply #8 on: June 25, 2011, 08:06:54 AM »
...and we are grateful for that passion and care!
I will wait to hear further whenever it develops.
Cheers
Henri
