Author Topic: CM 64 and copy channel  (Read 624 times)
Offline sjordan93436
« on: May 26, 2011, 10:18:08 PM »
CM 3.3.5
No big deal, but CM 64 does not seem to copy channel.  CM 32 does.  I open an image, select a channel, click the icon, apply.  Then control V or paste is empty.
BTW, I was trying to use CM and curve and then paste the channel into a mask.    PS pastes into a new layer.
Steve
Offline curvemeister
Re: CM 64 and copy channel
« Reply #1 on: May 26, 2011, 10:45:57 PM »
Thanks, Steve.  People have reported this bug a number of times, but I believe I missed the fact that it was a 64 bit only problem.
Re pasting to a mask: try alt clicking on the mask before pasting.
« Reply #2 on: May 27, 2011, 08:59:48 AM »
Thanks.  Keep up the good work.
