Help! I can't get CM installed on my new machine w CS5 64. I get a beta expiration notice. Also it can't find the plug-ins folder, which I manually pointed it too. I tried using the Photoshop internal update for the plugins, but that didn't work. At the end I had no CM at all!
DOH! Just read about the 3.3.3 and it solved the problem. Thanks! Recommend you update the update links.
