Author Topic: Two doors, one store  (Read 2469 times)
Offline art
Re: Two doors, one store
« Reply #15 on: March 23, 2011, 09:46:59 PM »
If all you wanted to do was to lighten the picture to reveal more detail, then all I did here was to use the Shadow/Highlight filter in Photoshop (at it's default settings).
Offline sjordan93436
« Reply #16 on: March 24, 2011, 12:46:22 AM »
Thanks for the corrections.  This started as an exercise.  I will print this special.
BTW- the exif shows an iso 1600 at 1/50 and f 4.0 (max for the lens).  In other words, at the edge.
Offline gremurphoto
« Reply #17 on: March 24, 2011, 07:44:26 AM »
"The solution to this problem is alimentari!"said Holmes,puffing on his pipe.GregM
