Author Topic: Zone system Pins...  (Read 1648 times)
Offline Greg Groess
Zone system Pins...
« on: January 21, 2011, 02:34:45 PM »
OK; so why would you need these....
I have been using these with some measure of success for single channel curving as a part of a modified Picture post card workflow.  Instead of guessing on the shadow and highlight I am using the Zone 8 and Zone 2 or 3 pins in each color channel I am choosing to edit.  It gets me into the "zone" faster.
They are by no means perfect...
I created these pins using Values found on the web for LAB associated with the Zone system.
Comments welcome including but not limited to...These are junk go away....
Offline Lee Harper
Re: Zone system Pins...
« Reply #1 on: January 27, 2011, 04:16:54 PM »
They're wonderful Greg - thanks for uploading them ;D
Do you still have the link for the webpage where you found the Lab zone system values? I'd like to have a read...
I still haven't got to grips with working the zone system into my regular workflow yet (keep meaning to ;)); these pins are a great carrot!
Offline Greg Groess
« Reply #2 on: January 27, 2011, 08:28:10 PM »
I keep finding that they help me in the single channels; for instance If I open a RGB file and open the G channel in PS I can then use the pins to help me place the tones for that channel more accurately it take some of the guess work and estimation out of the process and ki am finding right now that they help me set a much smoother curve.
Maybe it's me...I don't know yet but I am liking the results as I use it more...I'm hoping to post something soon that will show this off a bit.
Offline Lee Harper
« Reply #3 on: January 28, 2011, 12:49:32 PM »
I've just tried the pins on a few images, and so far - I am really impressed with the results I'm getting ;D
Do you think that there is any chance of getting Mike to have these install by default, so that they are easily available to everyone? I think that they are really useful; they would be a nice addition to the default installation.
One thing I'm curious about though - why does zone 0 have an L value of 2, rather than 0?
All best,
Offline Greg Groess
« Reply #4 on: January 28, 2011, 01:42:26 PM »
For my money 0 would drive the blacks all the way out...If you place it wrong you lock up a whole lot of image area...I found it made little difference in the end but had a strong aversion to 0 on the L channel.
I set my RGB Limits to be 5,5,5 when using CM in any case.
here is a screen shot from the page I found most of the data on...The author goes way too far with the explanation and covers some stuff that is not really relevant...
Offline WestMoon
« Reply #5 on: May 07, 2011, 11:39:44 PM »
hi and thanks for this thread and the zone pins
I bought CM about 2yr ago, and put it aside - I had so much basic photoediting to learn first! now that I have more context for it I am coming back to CM. I just upgraded to v.3.3.2.0 (is this the latest and greatest CM for XP32bit/CS3? - I haven't d/l the zone pins yet so will they work with this version?)
as soon as I saw the title of this thread I knew this idea was a winner! the CS5 professional user's handbook in its treatment of correcting colour describes a technique where the individual channel curves are adjusted for shadow and highlight (input values, with the aid of Threshold display, until shadows and highlights just begin to clip). can these pins be used in RGB (ie outside of LAB)?
obviously this is what you are achieving with these pins
further development of techniques based on these ideas would be welcome
just to repeat my questions:
do the zone pins work in CMv3.3.2.0
do they work in RGB
thanks
Neil
Offline WestMoon
« Reply #6 on: May 07, 2011, 11:48:39 PM »
one further question
how can these pins be added to CM, is there some help with this somewhere?
thanks
Neil
Offline Greg Groess
« Reply #7 on: May 08, 2011, 08:33:57 AM »
Neil,
There are a few ways to get the pins into the correct place.  You can right click on the pins gallery in CM and select "Manage Pin" files.  Copy the text file to the directory the other pins are located in and then right click and choose refresh pins or re-start CM.  The pins are generic for version and will work in older versions back to 3.0.1.  You can use the windows file manager to do the same thing if you are comfortable navigating to the "swatches" folder.
They work very well in RGB.
I created them in LAB so that I could work only with the L channel value.  CM translates them to RGB when you use them.  I have been finding pretty good results with these if you set the shadow and highlight using zone 2 and 8.  they can be pushed harder if needed.  Play around with them.
The way I use them is to open an Image in PS.  Select a single channel say Red...With Red selected I open the CM filter on the Channel.  You will get a B&W image with 1 channel in the CM interface.  Add your pins and adjust the contrast in the middle with a contrast pin as needed.  Then go on to the other channels.
I am working on a CM 201 Class that will work with this techniques and others that are just as interesting...in the mean time the next CM 101 class is coming up in a few weeks....
Keep asking and we'll get you the help you need.
