Author Topic: Help on all the customise options  (Read 677 times)
Offline themightyzog
« on: January 06, 2011, 10:44:13 AM »
Hi,  I've just got a 2nd screen, so I can now have full screen curves - absolutely great!
So I thought I would explore all the options and I have not managed to find help on some of them.
For instance...
Recent Curve List
Select All
HiLite Selection... (I can not remember making selections, how do I do that?)
Thanks and a happy new year to you all,
Zog
Offline curvemeister
Re: Help on all the customise options
« Reply #1 on: January 06, 2011, 04:08:00 PM »
Hi Zog,
Yes, having the curve separately on their own screen is super.  HiLite Selection is probably the same as HiLite Curve if you click on one or more control points, then the affected areas on the image are overlaid with a green mask.
Recent Curves is located under the curves tab, however it appears to always be disabled  I'll verify that this is the case, and add it to the bug list.
There are a lot of commands and options hidden in there - glad to see you trying some of them out!
