Author Topic: Try this image  (Read 2857 times)
Offline themightyzog
Re: Try this image
« Reply #15 on: September 03, 2010, 09:17:08 AM »
Well just as you thought you were knowing what you are doing, Dan has posted a new Man from Mars idea using the Equalize adjustment!
I actually prefer it as it does not require me to set lots of curve points and have been using it for the last 9 months or so.
Attached is the action -  try "=ise Man from Mars", which I adapted/enhanced.  You have to select the part of the image colours that interest you, when asked to do so and then continue/re-run the action.
The Color Theory Forum is worth joining http://tech.groups.yahoo.com/group/colortheory/
and he has written up this idea here http://tech.groups.yahoo.com/group/colortheory/files/Actions%20with%20Documentation/
Think you have to join before you can read it.
Enjoy
Zog
Offline gremurphoto
Re: Try this image
« Reply #16 on: September 04, 2010, 01:06:24 PM »
I tried two layers of lightness adjustment but couldn't get effect I wanted ,then went with shadow/hilight,then CS4 hue /sat,then CM for a neutral.
« Last Edit: September 04, 2010, 10:53:39 PM by gremurphoto »
Offline Lee Harper
Re: Try this image
« Reply #17 on: September 04, 2010, 02:21:30 PM »
On my monitor (not calibrated for a few weeks), everyone seems to be leaving the wooden areas at the top of the castle rather purple. ???
Are other people seeing this?
Offline gremurphoto
Re: Try this image
« Reply #18 on: September 04, 2010, 10:58:01 PM »
I added an image above with the magenta dailed back a bit.GregM
Zog,that second castle shot is neat.Disneyland-France?He really knew how to do castles.
« Last Edit: September 04, 2010, 11:01:43 PM by gremurphoto »
Re: Try this image
« Reply #19 on: September 05, 2010, 01:56:11 AM »
Nope Greg - it is for real, as is the whole town
Google "Carcassonne" and you will see
Chris
