Author Topic: Win7(64bit) /CS3 and CM3Demo installation  (Read 1421 times)
Offline gotto
« on: July 25, 2010, 04:28:52 AM »
I need your valued assistance please.. I am installing CM3 demo but get the following error message: Registration of some of the ActiveX controls and/or Type libraries failed.... The following controls could not be registered C:\program files (x86) Curvemeister.com\Curvemeister_3demo\curvectl3.ocx.
I do have VB redistributables installed
Any suggestions will be appreciated
Gerhardt
Offline Greg Groess
Re: Win7(64bit) /CS3 and CM3Demo installation
« Reply #1 on: July 25, 2010, 08:03:43 AM »
In Win7 you need to disable the user account control for the install of CM.  <known Issue that is being worked on>  If you re-install with the UAC turned off this should allow the control to register...If not post back and we will help you get it done through the regsrv32 process..
Offline gotto
« Reply #2 on: July 25, 2010, 09:28:50 AM »
Thanks Greg, such a quick response was not expected!   I have turned off UAC by selecting " never", restarted but still get the error message on installation. Would appreciate further assistance  Regards
Gerhardt
Offline Greg Groess
« Reply #3 on: July 25, 2010, 10:32:33 AM »
One way to do this is to manually register the OCX file.
Use a command window and at the prompt type "regsvr32 curvectl3.ocx"
This should register the ocx in the 32 bit space...
Offline gotto
« Reply #4 on: July 26, 2010, 01:00:39 AM »
Thanks Greg, attempted that with little windows knowledge and some memeories of DOS but get a 'Failed to find file' message I have copied the files into the same directory but to na avail. Any further help will be appreciated
Regards
Gerhardt
