Author Topic: 3.0.20  (Read 1190 times)
Offline julie
3.0.20
« on: March 23, 2010, 07:20:41 AM »
Downloaded this 2 days ago and it has just stopped working. Curvemeister does not show photo when it opens and says encountered improper arguement. Occasionally nothing happens at all. I had been using 3.0.19 until then.
Any suggestions.
Offline curvemeister
Re: 3.0.20
« Reply #1 on: March 23, 2010, 08:06:25 AM »
Hi Julie,
Are you running on a 64 bit system?  If the answer is no, I'd suggest backing off to an earlier version of Curvemeister, v3.0.12 until this problem is fixed.  Previous versions are located here:
Re: 3.0.20
« Reply #2 on: March 23, 2010, 09:04:27 AM »
Hi Julie,
If would like a ticket assigned to this problem, please email a note to support@curvemeister.com.  This will make it easier for me to notify when the solution is found.
