Is there a 64 bit version of 3.0.19? - Brian
Mike,tried uninstalling again and it appeared to 'take' - cleaned reistry with Desktop Maestro and re-installed - Note instal run As Administrator and UAC is off.Problem still remains for me as follows:-Load Curve, Browse History, Browse Library all cause crash of CM-64/CS4-64-Using a curve that appears in the dialog box is OK, but Browse to = crash-Favorites list appears and they can be used - note that the 32 bit Folder is accessed however Browse Favorites = crash-Open a Pin File = crash-Adding a pin file to the CM64 Swatches folder = crash on opening CM64
Note that other than Favorites, CM64 aims at the ProgramData/CM64 folder for History, Library, Swatches.I have a suspicion that there is some conflict in folder direction and/or folder permissions - because the crash (mostly) occurs by just accessing the Folders.
Also as above, CM 64 persists in looking at some CM32 folders and BTW I just noticed that CM32 persists in using CM64's History folder (CM64 was installed after CM32).
Which raises another question - why is there a need to have duplicate History, Library, Swatches folders for CM32 and CM64? I can't imagine anyone needing to run both 32 and 64 CS4 at the same time.
