Mike,I have had this version fail and Kill PS or PSE with the same error. It is very consistent and persistent. I have un-installed and re-installed 3.015 and the error is still there...See attached.Greg
[re new version 3.0.18]So how did you get hold of it?Zog
The 32 bit versions of Curvemeister 3.0.18 are available in the download locations for the respective products. I recommend that you upgrade to this version - beta versions expired on Jan 1, and older production versions of curvemeister will be missing some significant improvements.
Hi Ron,This is definitely not the expected behavior. The installer did not find your previous version to perform an un-install, and probably installed the new version in the wrong place. Needless to say, this is not satisfactory and I'd like to figure out what happened.One possibility that comes to mind is that you have UAC enabled on Vista, and/or the account that you used to perform the install does not have admin permissions. If that doesn't ring a bell, let me know. I'd like to chase down this problem as soon as possible.
Ron,Do a quick search for Curvemeister.8BF and see if it is located on your system in one of the curvemeister folders. Check the build dates. Sometimes the 8BF does not get copied to the CS3 filters folder because of "folder protection" Adobe sets.
