Author Topic: Problem  (Read 1510 times)
Offline gremurphoto
Problem
« on: October 26, 2009, 08:56:32 AM »
This is what I get when I try to set highlight.I might have something toggled wrong somewhere?GregM
Offline Greg Groess
Re: Problem
« Reply #1 on: October 26, 2009, 09:13:39 AM »
Does that always happen or just this image??
I have seen it once in a while on my install but it usually goes away if I close CM, Close and re-open PS.
If it is the image can you post it so I can try it out??
Offline gremurphoto
Re: Problem
« Reply #2 on: October 26, 2009, 10:01:50 AM »
It happens with all images.Noticed it a few days ago.Can work around it but wonder what's happening.GregM
Offline Greg Groess
Re: Problem
« Reply #3 on: October 26, 2009, 10:27:42 AM »
What version are you currently running??
Offline gremurphoto
Re: Problem
« Reply #4 on: October 26, 2009, 12:39:11 PM »
v3.0.12  GregM
