Author Topic: bug and flower  (Read 2500 times)
Offline gremurphoto
bug and flower
« on: October 01, 2009, 11:03:32 AM »
Another white flower.Suggestion,use shadow/highlight in Photoshop to recover lacey detail in petals even at six o'clock. Also note small deposit of yellow pollen nearby.GJM
« Last Edit: October 01, 2009, 11:06:07 AM by gremurphoto »
Offline Greg Groess
Re: bug and flower
« Reply #1 on: October 01, 2009, 11:14:23 AM »
This one is fun...Try it for yourself...
Push the color..."Petal to the Metal" as Mike would say....Try a K mask and some wild curves to see if you can limit the effect to make it believable..
Wildest believable color wins....
I used Lab with a technique we will learn later that is a modified version of the Dan Margulis "Man From Mars" maneuver.  In CM we can limit the effect with a Mask in the K channel that acts like a filter.  Crank on the saturation slider in the bottom of the LAB window in CM and then limit the effect using a K channel mask and a curve.
« Last Edit: October 01, 2009, 11:23:49 AM by Greg Groess »
Offline gremurphoto
Re: bug and flower
« Reply #2 on: October 01, 2009, 11:38:52 AM »
Very impressive.I like the black pinstripping to the magenta rays.GregM
Offline Greg Groess
Re: bug and flower
« Reply #3 on: October 01, 2009, 12:11:06 PM »
I thought they looked rather burgundy.  Check them out...
« Last Edit: October 01, 2009, 12:12:58 PM by Greg Groess »
Offline ThomasD
Re: bug and flower
« Reply #4 on: October 01, 2009, 12:21:42 PM »
Here is my try, quick one (and dirty?). Concentrated on the flower. Started with a first level adjustment in Elements. Then selected flower in elements. Went to CM lab mode adjusted neutral, white and black and increased colour sat. Back to Elements and sharpened flower and blured background. Not very refined but fast.
Offline Greg Groess
Re: bug and flower
« Reply #5 on: October 01, 2009, 12:30:19 PM »
And yet...
I like this one as well...It brings the flower out....
What a FUN Image...Thanks Thomas....
Offline gremurphoto
Re: bug and flower
« Reply #6 on: October 01, 2009, 02:29:31 PM »
Burgundy,that's something I buy by the jug.GregM
Second image is the little guy before he landed.
« Last Edit: October 01, 2009, 02:50:52 PM by gremurphoto »
Offline themightyzog
Re: bug and flower
« Reply #7 on: October 02, 2009, 09:55:28 AM »
I normally use PS7, which doesn't have a S/H feature, so I thought I'd try something a little different.
Once again the image is quite out of focus and so I used MagicFocus to recover some of the detail
I'd never have thought that there was so much detail in the whites - I pushed the pedal through the floor on this one, didn't stop at the metal!
Once again I added blur as the last step
Offline Greg Groess
Re: bug and flower
« Reply #8 on: October 02, 2009, 10:59:48 AM »
OK Zog...That scared me....
Wow look at the Details.....
Offline gremurphoto
Re: bug and flower
« Reply #9 on: October 03, 2009, 03:59:33 PM »
I'm left speechless.GregM
