Author Topic: What is the software to read data on windows partition from linux partition?  (Read 2290 times)
airiness82
  • Guest
I am using dual boot system and i want to know the software for reading data on the windows partition from the linux partition...
I want to use linux but data are all in the windows partition...
Is there any software for reading the data ?
Thanks
Kriston
Offline curvemeister
Hi Kriston,
A bit late to the game, but there is a freeware application called ext2fsd that may get the job done.
http://www.codejacked.com/automatically-mount-your-linux-partition-in-windows/
Another possibility is to run Linux virtually under windows, and share the partition over the network.  This has the added advantage of making your Linux system available while Windows is running.
Hi Karl,
Thanks for that - yes, WINE is an interesting platform.  It allows you to run windows programs on the Mac, and perhaps on Linux.  Perhaps you know something I don't - always possible - about going the other direction.
